Dakota load levelers
Laz
North Carolina
Hey guys thank you in advance for for your assistance. I have a stock 2006 4x4 liberty. I have read that allot of folks use the Dakota's load levelers on the lifted liberty's. My question is will they work with a stock liberty. I am trying to increase pay load capacity and a extra inch of height would be great.
Thanks
Thanks
No will work on a lifted KJ, not stock least not the ones for a 99-04 dakota crew cab 4x4
JasonJ
Michigan
Got it thanks
Monroe does not list a load-leveler that fits the stock KJ. If you look at their product specs pdf that lists the capacity/weight of each shock, and it's compressed and extended length, as well as bolt hole width, you may be able to find one that works, but that'd be on you to research.
Otherwise, you could put air bags in the rear to help with load carrying.
scbison
I wanted to bring this back from the dead. Any clue if this will work with a small lift vice a larger one. i.e. using OME 947 springs in the rear?
u2slow
BC
I use them with 4runner coils.... takes the 2" lift to about 3".
I'm lifted, have Ome 927 front / 948 rear coils on KJ.
I installed Monroe rear shocks #58649 load levelers. Handles weight well.
Yes I remember that Luke. You had lots of weight in the back..;)
