Originally Posted by Tinkrr
I replied to this a few days ago from a campground WiFi and it is not in my sent folder so here goes again
I ordered my CC Kit from Jeepsareus they had 10 kits in stock at the time for 05 KJ 3.7 Litre eng.
They emailed the installation instructions to me when I placed the order. The kit was complete and took just over an hour to install and test it.
-Disconnect the negative battery lead
-remove the steering wheel cover bolts(2)
-disconnect the air bag ground cable at both ends and remove
-Remove the switch blanks and install the CC switches(2 screws)
-Install new cable and plug into the steering wheel the two CC switches and the air bag ground
-remove the air hose from the cold air box to the throttle body and the PCV system(2 Hose clamps
-remove the cold air box
-install the servo/vacuum motor
-remove the throttle cable(retainer clip and push small detent on bottom ofthe cable)
-slide CC cable into the throttle cable and hook to pin on the throttle
- replace the throttle cable and retaining clip
-hook up the vacuum hose to the ont under the coolant expansion tank
-replace the cold air box,hoses and reconnect the negative cable to the battery
-close the hood your done
-Time for a test drive
The kit is complete with genuine MOPAR parts and nothing extra is required.
The only problem i experience was a Plastic Tee o the PCV system broke(crumbled) when I removed the hose from the air filter box. I'm assuming the Tee was embrittled from engine heat.
