CRD PCV Help.....
Sherm123
What one do I need to buy???? I’ve seen a lot online and some of the bigger engine models say pvc but looking at my 2.8 everywhere’s selling CCV? I’m so confused ‍♂️
Sherm123 Welcome.
It should be part pressure control valve #5114348AB.
To confirm with your vin# you could call your local dealer.
Here is the 2006 parts fiche if you also want to search for it.
http://www.colorado4wheel.com/manuals/Jeep/KJ/06kj_PARTS_FICHE.pdf
Since it is a crd, & for less confusion, I deleted your KJ section poll post in favor of this crd post.
turblediesel
memberable
Alaska
The CCV is "the hockey puck" on top of the valve/cam cover. The o-ring can croak from heat and leak nasty black oil all over that area of the valve cover. Also, there's a drain-down hole in the valve cover below the hockey puck that can plug up and cause more leakage past the o-ring.
A hose comes off of the hockey puck that goes to the bottom of the big air intake hose that runs between the air filter box and turbo charger. The big air intake hose tends to rot out on the bottom due to oily air coming from the hockey puck. That lets extra unfiltered air in that alters the airbox sensor readings.
Some owners run the small hose coming from the CCV-valve/hockey puck down below the engine to atmosphere and plug the hole in the air intake hose. This is known as "the elephant hose mod" and it's not a good idea for two reasons. In cold climates the end of the hose can ice up and blow the rear main engine seal, and, it pollutes a lot.
The best solution is to add a Provent air/oil seperator to the hose coming from the hockey puck and keep the air intake hose from rotting out. Sasquatch Parts makes a nice kit to do that and they also have a rot proof silicon air intake hose.
ID Parts is a good source for 2.8 CRD stuff like the CCV-valve/hockey-puck.
Sherm123
Thank you mate! Is ID parts a website? Sorry mate, I’m Farley useless at this type of thing
turblediesel
memberable
Alaska
Yup, ID Parts has a website. They mostly supply parts for VW diesel owners but they branched out to serve other diesel afflicted brands and owners.
LOSTJEEPS forum has the most info on your 2.8 CRD. Sometimes depressing, but useful.
