Crashed 2002 Jeep Liberty
mr.KJtuff
Franklin, Ohio
I haven't been on in a while, had been enjoying my Liberty when a drunk driver smashed into it on 1/9/19. Clipped the right rear corner spinning it around 180 degrees. Snapped the axle on that side, breaking the wheel off at the drum. So, I am going to junkyard tomorrow morning to retrieve a complete rear end assembly. Going to be cold, wondering what is the fastest and easiest way to remove? I also have to grab the rear fender flare and rear bumper. Feeling pretty comfortable grabbing both of those. Just looking for some easy advise for the rear end removal?
Thanks
Thanks
Pretty easy to drop the rear diff, remove shocks, lower control arms upper control arm, and on yours will have to remove brake line since it has drums, ( later models with calipers super easy)
Make sure you get one with correct gearing to match yours
JasonJ
Michigan
Agreed.. once you see that there are really only about 4 attachment points for the rear axle, shocks, upper control arm, lower control arms, driveshaft... it'll drop down fairly easy.
Actually.. if jacked up a bit, once released, it may be easier to just jack the vehicle up higher and leave the axle on the ground, tires to pavement and just roll (drag?) it out from under the vehicle.
Sorry to hear about the crash, glad you're fixing it rather than scrapping it!
mr.KJtuff
Franklin, Ohio
Do you think I should grab the trailing arms too, or do you think they would have been strong enough to not sustain any damage? Frame did get bent. Please advise?
Sorry, frame did NOT get bent!
Hard to see if the rear lower control arms are good or not when bolted on, but after removing one end, you can look at them
Every 4.10 rear diff I have gotten from a yard had shocks, LCAs etc still attached
mercdudecbr600
If broken wheel I’m guessing lca got bent
mr.KJtuff
Franklin, Ohio
Thanks, everyone! I was able to get all the parts at the junkyard this morning, with little difficulty. Now the repairs will begin to get it back on the road! Will advise when I rejoin the fray! Thanks again for all the helpful advise! I appreciate it!
