Couple of Questions
carterdea
Hello,
I am having my friends do speaker and amp install in a couple of days, and I have a couple of questions, is there anything special we need to do when taking off the door panels? And what about the dash (to get to the tweeters)?
Also, what would you suggest as to keeping my stock wires or replacing them?
And how do I trick my deck into thinking that I'm in park? (to make video work)
And lastly, If I have fog lights, and I don't want them, is there a way to take them off and make it look good?
thanks
carterdea
06Liberty
Odenville, AL
Well, the only thing I have any experience with is the door panels. Just dont start yanking on em, be careful not to break the clips. But, you have to pull kinda hard to get em off...it's sort of a fine line between breaking clips and getting the panel off.
carterdea
Thanks, that helps, but What would happen if I were to accidentally break the clips?
06Liberty
Odenville, AL
You can go to autozone and they shoud have em, or we have an ace hardware here that has all kinds of clips like that you can buy for real cheap. If not, they should have something close enough at just about any auto parts store.
sqliberty
chicago
carterdea said:
Hello,
thanks
carterdea
Whay kind of video deck are you using?
billforde
Seaford, NY, USA
sqliberty said:
carterdea said:
Although it is illegal to watch while driving and I don't recommend it, if you want to do this for car shows or something you should be able to take the wire that goes to the brake and ground it.
Technically, your suppose to attach it to the emergency brake, so that it will only turn on when the emergency brake is set. But thats technically (whistle)
carterdea
i don't plan on watching TV or movies while driving, so don't worry. i thought it would be cool to use it for music videos and such while driving, just to show off I guess.
