2003 Jeep Liberty
80k miles
Automatic Transmission
3.7L V6
Past repairs include: Broken valve spring. Replacement transmission ECM. All new plugs (3/13). 3k mile oil changes. Crank sensor x 4. Cam sensor x 3. IAC/TPS sensors x 1. Battery x 1 (3/13).
We've had this problem since early this year. It started off as the Jeep would die at stop signs without notice. A gentle stall, no jerking. Code said crank sensor, so we changed it and reset the PCM. Problem fixed.
Wrong.
Did the same thing again but this time it was the cam sensor. Again, replace, reset, fixed.
Nope.
Fast forward four months and we're still dealing with this issue. The car will constantly show the crank/cam sensor code(s) and be without symptoms. Then it will randomly just not start. It tries to turn over, has fuel and spark. But it just won't. It just cranks and cranks and cranks, about every four times it'll fire but it won't go over 2k RPM. All I have to do is reset the PCM and it runs fine again for a few weeks.
Bad PCM?
Bad Coil?
Short in the wiring harness?
I'm completely out of ideas and I'm about to sell it just to get out from underneath the loan and take a loss. I've never had this much trouble with a Chrysler product but this takes the cake. I'm well over $2k in repairs and diagnostics without a true fix, just band-aids.
80k miles
3.7L V6
Wrong.
Nope.
Bad PCM?
Bad Coil?
