zzAMBIENzz
I feel like this is a really "noob" question, but:
Would I still show good compression if timing was off?
I have been chasing my tail for 2 days now, looking for the cause of the entire passenger side bank being dead. (cyl 2-4-6).
The Jeep starts and runs "decent" (as decent as you would expect running on only 3 cylinders). I have determined via dropping the coils that 2-4-6 are all dead.
Today I tested each coil, and all had great spark. I tested each injector socket with a noid light, and they all had pulse.
I also did a standard compression test, and all cylinders had 155-160 psi.
My initial thoughts on the problem was that timing was off. The engine has clearly been recently rebuilt, or at the least, has had head gaskets done. The compression test is throwing me off though. That seems like almost perfect compression. I would have expected either low or erratic numbers if the timing was off bad enough to have completely dead holes.
I am just looking for any information before I start stripping the front of the engine apart. The last thing I want is to tear it all the way down, only to find that wasn't the problem.
