cnat access computer to retrieve error codes
rwms498
canada
hi. i have a 2006 liberty 3.7 l engine. mechanic retrieved error code a month ago, but forgot code and didnt write it down, so when he tried to retrieve code the second time he couldnt get into the system. he has used two seperate professional quality code reader "thingys" to try to access....has anyone run into a similar situation? i would greatly appreciate any help. thanks.
wheeee32
Not the mountains.
I'm gonna go ahead and ask if you already tried the turn-key method to see if codes pop up on the odometer display.
hilltopmike
nor cal
Cranks no start, no spark, no injector pulse. No bus is displayed on odometer, no scan tool communication.
Average Reported Mileage:
92791
Tests/Procedures:
1. Check the 5 volt reference wire on the Orange wire at the Camshaft Position (CMP) sensor.
2. If not 5 volts, unplug the CMP sensor, cycle the key off and on and recheck for 5 volts.
3. If the 5 volts is present with the CMP sensor unplugged, the CMP sensor is shorted.
