Clutch Noise??
vomari
Hello Jeep KJ Country,
Just purchased a used 2006 jeep liberty (stick) and after a few days of driving it I started hearing a squeaking noise as I press down on the clutch. I thought I'd did thorough research by looking up recalls for this year and model. Not one to be found for a manual.
Is this common? Does anyone have an idea of what it could be, before I go take it back to the dealership under a 30 day warranty?
Thanks
Prospect62
New Hartford, NY
For what it's worth, my clutch pedal itself makes a squeaking noise sometimes. I think it's the pivot point where pedal itself is attached or the master cylinder pushrod or something. Usually only does it during the winter when it's cold and filthy in my Jeep.
It's completely unrelated to the mechanical portion of the clutch/transmission and not at all a serious problem. It's just another noise.
See if you can isolate where the noise is coming from - is it coming from the clutch itself or just the pedal? Just something to consider before you tear into your clutch. :)
EDIT - I just saw you're still under warranty. Take it back and let them figure it out. Good luck!
vomari
Thanks prospect62, that's what I'm planning on doing.
