CJC Transmission pan
CheddarGau
Lower Mainland BC
A while back I came across some who showed a pic of what I think is a CJC transmission pan. How have you liked it and have you noticed a difference in performance, cooling, etc. I want to say it was lfhoward, but I can't remember.
I have a 42RLE PML aluminum machined transmission pan installed with a Lube Locker Gasket. No more leaks again.
Has a drain plug & optional temp sensor (extra $) The pan alone keeps things cool !
It is best to also have a transmission skid plate. The OEM skid plate is rare to find today.
WWDiesel
Central Georgia
I added the deep sump PML transmission oil pan a few years ago. It made a big difference in lowering and keeping transmission fluid temperatures in the 180-200 degree range when towing heavy loads in the hot humid south where I live. Great pan, with drain plug and a port for a gauge fluid temperature sensor.
I too have installed the PML pan and am happy with it. It DOES NOT have internal cooling fins, but it does seem to lower the trans temps. Unfortunately I used RTV to install it, I didnt know about the gasket. No leaks though.
