Can someone help me identify these lines?
FrozenAvocado
One of them is leaking from what I'm seeing. It's from a 2004 kj 3.7 L V6. Haven't had any luck searching online.
Robochop
Robochop
Virginia
Transmission Lines! You can disconnect and replace with higher pressure rubber hose lines. Be sure to secure them so they don't rub against anything.
Xterra4x4
Follow the lines, they appear to be lines to the heater-core, transmission lines run between ****** along oil pan to the front of the motor,then to ****** cooler!
LibertyAZ
I had same issue recently and repaired them. Repairing them is much cheaper and easier than replacing. This video helped me:
