Can I get an alignment before rear control arm replacement?
GitEmSteveDave
Howell
Short story long, recently I've been traveling 50+ miles each way daily to visit someone and in the rain at highway speeds(above 60 mph), through the seat, my Libby feels loose. I didn't feel it in the wheel, but in my butt. Then later that night while getting on the Parkway, the rear slid out from underneath me, and I fishtailed a second or two, but recovered. I kept it under 60 the rest of the way home, and luckily I haven't had to take her out on wet roads, at speed, since. I bought the tires in 2020, have 55,000+ miles on, and they're all a thumbnail away from the wear bar
so I decided to replace them all, because one was plugged in 2023 and another has a intermittent slow leak I can never seem to source. I'm getting the tires tomorrow.
But I also wonder if maybe my rear control arm(s) have finally given out. I know when I bought it, my mechanic said the boomerang was fine, but the lower control arms were a little rusty. I also ran over a piece of rebar a landscaping truck dropped with my front passenger tire and heard it bounce it's way down my undercarriage a week back. I pulled over and made a visual inspection, but didn't notice anything and there have been no major difference in drips and drops in my parking space(Bless those skid plates) I made an appointment with a new mechanic on Wednesday(my old mechanic is no longer close to my job, so it's not easy to drop it off and pick it up after work) for an oil change, so I'm gonna ask him to check the arms and if he sees any damage from the rebar.
My question is, I've never had her aligned in the 6+ years I owned her, so I was gonna do it at the tire place. If I get it aligned, and then need new control arms, will that screw up the alignment?
Old tyres can be nasty, however on a KJ a worn ball joint on the front can make the handling awful, jack it up corner at a time and have a good wriggle on the wheels, any movement or knocking needs looking at, be really thorough, most issues are front end related. Check for steering gear wear as well.
Worn rear lower arm bushes let the rear axle steer. Especially noticeable with a heavy trailer on the back... makes you grip the seat with your rear end when you hit a bump going round a corner and the Jeeps rear suddenly steers itself! (Been there!)
If the rear bushes are shot to bits then the axle may be wondering about, the only thing that aligns it is the lower arms, the lower arm body side bushes aren't solid, they have voids ls to allow movement, unfortunately the rubber splits into the voids letting them flop around.
The top arm just stops the axle moving back and forward as you drive, this usually gives you heavy thump from the rear as you speed up or slow down.
The other thing to look at is the springs and shocks, if they are original they are probably very worn, what's the measurement from the centre of the wheel to the underside of the wheel arch?
An alignment certainly won't hurt but loose handling suggests something is worn out, I'd get that sorted first and then align it so you don't wreck your new tyres or have to pay twice.
GitEmSteveDave
Howell
OK, I'm writing a note to the mechanic so he knows what to ignore on my libby, like the check engine light, so I'll have him check those things.
The alignment isn't about the loose handling, it's like you said, I don't want to wreck the new tires, not that I have noticed any unusual wear, but on my recent journeys, I have hit a bunch of potholes at speed that will rattle your teeth and make the inside ligths flash on.
GitEmSteveDave
Howell
So got the tire changed today and they told me I need outer tie rods before they could do an alignment and they would call me back later with a quote. I'm already beholden to my new mechanic for the rear control arms, so I feel like I should tell them about the tie rods.....
GitEmSteveDave
Howell
So I decided to go with the tire people for the tie rods, which at $375 for parts and labor, the price seemed right, but the mechanic I asked to look at the rear control arms has never done them on a Liberty before, according to him, and he is telling me it might require torches and welding because in NJ we are exposed to the rust belt. Almost every video and guide I have seen doesn't suggest this, so I think I should move on to someone who has done work on an actual Liberty.....
Mine are on a UK Jeep, we have rain and road salt by the bucket load, brute force and an impact gun have never failed me yet on any underside stuff, just be aware that all the bolts are metric and use unusual head sizes- 15mm, 18mm etc. Use the wrong size, an imperial socket or a 12 point socket and you will round the head off, make sure your mechanic has decent metric gear.
I'm currently having far more trouble with the bolts on an old B&S 6hp than the Jeep has ever given me! :confused:
GitEmSteveDave
Howell
So I brought it to a local, highly recommended, repair place, which does current USPS vehicles and said they used to work on USPS jeeps. They had it an entire day and never called me, so I called them at 5pm. Mechanic tells me he's never done a Liberty and worried he has to torch the rear control arm mounts to get the unit out. I had already spent some time on here and youtube looking as to what was involved, and that seemed crazy to me. I know youtube videos aren't gospel, but total replacement of the rear control arms doesn't seem to be an all day job, so I bowed out and just asked them to do the oil change, which they didn't do after yet another day with my Libby. So 3 days in the shop with nothing done. I have to go in early tomorrow to get the oil change done.
So I'm now gonna drive it 50+ miles to my fathers mechanic next week, who knows what a boomerang is and has told me that unless every bolt isn't seized, he can likely get it done in 2 hours. I have already started spraying the lower and upper control arm bolts with PB'laster and will do so every night until I bring it up, so they will get 4 days of treatment, with driving, to loosen them.
It ***** when you move and can't easily get to your trusted mechanic and also can't do the repairs on your own.
