can build sheet be wrong??
twindragons187
i'm just curious if a build sheet could be wrong? there's some things on my sheet that make no sense to me. like i have an 03 jeep. build date is 1-03 and cross member for ****** goes back towards rear and i have the box on the pass side fender for the 45 ******. on my sheet it says i have the 42 and also on the door jam, says my stock tire is the 215/75/16 and on the sheet it says 235/70/16......i'm confused....:confused:
twindragons187
here's my sheet
*M5 Cloth High-Back Bucket Seats
-DV Dark Slate Gray
AHMP Convenience Group I
AJPP Power Convenience Group
APAS Monotone Paint
A90P 3.7L Eng (EKG)/4Spd A/T 42RLE (DG6)
BAZS 136 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BRES 4-Wheel Disc Brakes
CF5S Rear 65/35 Folding Split Seat
CGUS Child Seat Anchor System-LATCH Ready
CG1S Next Gen Multistage Front Air Bags**
CKDP Floor Carpet
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CK3S Plastic Swing Gate Trim Panel
CLEP Front & Rear Floor Mats
CLHP Cargo Trim Panel w/Storage Net
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CTLS Base Door Trim Panel
CUFS Full Length Floor Console
DGAS All 3-Speed Automatic Transmissions
DG6 4-Spd. Automatic 42RLE Transmission
DHAP Lock-Up Torque Converter
DHNS Command-Trac Part Time 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Axle Ratio
DRAS Corporate 8.25 Rear Axle
EKG 3.7L V6 Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEG Deep Tint Sunscreen Glass
GEKS Flipper Swing Gate Glass
GFAS Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNCP Sun Visors w/Illum Vanity Mirrors
GT9P Power Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMP Remote Keyless Entry
HAAP Air Conditioning
I63S Route 63 - CSX, Twin Oaks, PA
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JJMP Auxiliary 12-Volt Rear Power Outlet
JPHP Speed Sensitive Power Locks
JPYP Pwr Windows, Front 1-Touch Down
KJSS STRIPE/BADGE/MOLDING/COLOR
KLSS STRIPE/BADGE/MOLDING/COLOR
KRSS STRIPE/BADGE/MOLDING/COLOR
K3AS STRIPE/BADGE/MOLDING/COLOR
LACP Illuminated Entry
LCDP Map/Dome Reading Lamps
LDBP Cargo Compartment Lamp
LHDS Headlamp Off Time Delay
LMAS Halogen Headlamps
LPSS CHMSL Lamp
MDAS Front License Plate Bracket
MFKS Body Color Grille
MLCS Gray Fascias
MVCS Jeep Badge
MWGP Roof Rack
NAS 50 State Emissions
NBGP Federal Tier 2, Bin 9A Emissions
NF2S 18.5 Gallon Fuel Tank
NHFS Power Steering Cooler
NHM Speed Control
PJC Light Khaki Metallic Clear Coat
QJCS Light Khaki Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RBK AM/FM Compact Disc Radio w/Chgr Ctrl
RCGS 6 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TSA P235/70R16 BSW All Season Tires
TZAP Goodyear Brand Tires
WKBS Matching Spare Wheel
WLCP 16X7.0 Lux Styled Steel Wheels
WLYC All Steel Wheels
XGGS Grocery Bag Hooks
XJFS Tethered Fuel Filler Cap
XPFS Protective Coating and Remover
YAAS Build To U S Market Specifications
YEP Manuf Statement of Origin
YGEA 5 Additional Gallons of Gas
ZCHP Spring - Left Front
ZCUP Spring - Left Rear
ZRGP Spring - Right Front
ZRUP Spring - Right Rear
5I4S Four Wheel Drive (4WD)/(4X4)
5I8S Left Hand Drive (LHD)
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
Yes, the build sheet can be wrong. There's a few people on here who have the 42RLE and their build sheet states that they have the 45RFE.
Straight6Jeff
Salem, NH
build sheets are commonly wrong. What ever seems to be laying around is what is put in. I had a 1995 chevy c1500 that had more c2500 parts on it than 1500 parts, even though the build sheet said otherwise. It was a real PITA the first couple of times I went to get parts for a c1500 and realized they were wrong.
The spring codes on my build sheet are not what are actually in it
Marlon_JB2
Kombat Edition Jeep
That's exactly how it's done. The line isn't gonna stop just because a certain tire or fan shroud isn't in stock at the time. Now maybe something like bumper covers or ... engines... yes.
The sticker on the door is generic. I had 235/65/17's but they were not on that door sticker.
I would demand the 45rfe if it said I should have it but I didnt!
twindragons187
it says i have the other ******(42) but everything on the jeep says i have the 45???
p.s.
it also says nothing of the ****** cooler thats on the jeep either.
desertkj
Arizona
I'd say you lucked out with that one. LOL. I have also had the same issues with tires. I always thought 235/70/16 was the standard size and now I realize that my tires seem oversized compared to most KJs I see.
Straight6Jeff, although getting parts was a pain, not bad to get most of a 2500 for a 1500 price.
