Build Sheet
Shoey
Harrisville, WV
Got my build sheet from Chrysler. This one was pretty loaded.
Vehicle Description JEEP LIBERTY LTD EDITION 4X4 SPORT UTILITY 4-DR
Model Year 2003
Body Model KJ J P 74
Color PS2 Bright Silver Metallic Clear Coat
Sales Code Description
*DL Prem Leather Trimmed Bucket Seats
-L2 Lt Taupe/Taupe
ADLP Skid Plate Group
AHMS Convenience Group I
AHT Trailer Tow Group
AJBP Security Group
AJPS Power Convenience Group
APAS Monotone Paint
AWL Off Road Group
A90P 3.7L Eng (EKG)/4Spd A/T 42RLE (DG6)
BAZS 136 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BRY Anti-Lock 4-Wheel Disc Brakes
CF5S 2nd Row Buckets, Power Fold/Tumble
CGS Supplemental Side Air Bags
CGUS Child Seat Anchor System-LATCH Ready
CG1S Next Gen Multistage Front Air Bags**
CKDP Floor Carpet
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CK3S Plastic Swing Gate Trim Panel
CLES Front & Rear Floor Mats
CLHP Cargo Trim Panel w/Storage Net
CSAS Spare Tire Cover
CSCS Cargo Compartment Cover
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CTCP Luxury Door Trim Panel
CUDP Mini Overhead Console
CUFS Full Length Floor Console
DGAS All 4-Speed Automatic Transmissions
DG6 4-Spd. Automatic 42RLE Transmission
DHAP Lock-Up Torque Converter
DHPP Selec-Trac Full Time 4WD System
DJJS Dana 30/186MM Front Axle
DMES 3.73 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle
DSAP Trac-Lok Differential Rear Axle
EKG 3.7L V6 Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGP Deep Tint Sunscreen Glass
GEKS Flipper Swing Gate Glass
GFAS Rear Window Defroster
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GUWP Pwr Htd F/Away,Drvr Auto Dim Mirrors
GVBC All Vehicles W/Power Mirrors
GWA Power Sunroof
GXMP Remote Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAAS Air Conditioning
JA2S Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JJMP Auxiliary 12-Volt Rear Power Outlet
JPHP Speed Sensitive Power Locks
JPM Heated Front Seats
JPTP Power Front Driver/Passenger Seats
JPYS Pwr Windows, Front 1-Touch Down
K2SS BRT. SILVER MET. C/C - Molding - B
K5SS BRT. SILVER MET. C/C - Fender Flare
LACP Illuminated Entry
LAZP Vehicle Information Center
LBBP Courtesy Lamps
LCDP Map/Dome Reading Lamps
LDBP Cargo Compartment Lamp
LETP Traveler/Mini Trip Computer
LHDS Headlamp Off Time Delay
LMAS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MDAS Front License Plate Bracket
MFKS Body Color Grille
MLAS Body Color Fascias
MSUS Limited Edition Badge
MVCS Jeep Badge
MVDS 4X4 Badge
MWGS Side Roof Rails
MZLP 3.7L Badge
MZ3S Liberty Badge
NAS 50 State Emissions
NBGP Euro Stage 6 Emissions w/EOBD2
NF2S 18.5 Gallon Fuel Tank
NHFS Power Steering Cooler
NHK Engine Block Heater
NHMS Speed Control
NMCP Heavy Duty Engine Cooling
QS2S Bright Silver Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RBPP AM/FM Cass/CD Radio w/Changer Ctrl
RCJP 6 Premium Infinity Speakers
RDDS Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
SBAS Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SDAS Jeep IS43 Suspension
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TSNP P235/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WKBS Matching Spare Wheel
WLDS 16X7.0 Lux Aluminum Wheels
WLZC All Aluminum Wheels
XEAP Tow Hooks
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XEUP Front Suspension Skid Plate
XFJP Class III Receiver Hitch
XFKP 7 Pin Wiring Harness
XFLP 7 to 4 Pin Wiring Adaptor
XGDP Universal Garage Door Opener
XGGS Grocery Bag Hooks
XJFS Tethered Fuel Filler Cap
XPFS Protective Coating and Remover
YAAS Build To U.S. Mkt. Specifications
Also found out from the Carfax I'm only the second owner. That's pretty refreshing haha. No real point to this thread, just wanted to share. Will be making a build/maintenance log soon.
Thanks for reading!
Shoey
Harrisville, WV
Knock on wood, but other than the leak, which is fixed now, the transmission is working great, even at 140k miles.
I probably just jinxed it though.
where was your leak? Mine has an extremely slow leak by the pressure sensor.
I'm on the same boat as you are but I was lucky to have the 45RFE.
Getting new tires on Thursday.
On Sat, I'm doing a brake job, changing the PS hoses, replacing the tensioner and the E-radiator fan.
Shoey
Harrisville, WV
Corner of the pan close to where the exhaust crosses over. Brakes are soon too, and I have some annoying squeaks and clunks I have to diagnose.
KodiakKJ
Colorado Springs, CO
When I got mine, they only got the year, drivetrain and model right. Mine was apparently a Atlantic Blue sport with cloth seats and automatic transmission.
Sent from my Lumia 1520 using Tapatalk
metalmoto
Philadelphia
My build sheet seemed spot on. Except for the illuminated ashtray (perhaps the bulb is burned out?). And the second row "bucket seats" with power fold tumble? They look like bench seats, and where is the "power fold tumble"?
Also, the 6 CD changer is missing. All I have is a wire with a DIN plug in the cargo area?
Where is the changer supposed to go? Does it just sit back there? I am confused...
Changer is built in to the passenger side rear cargo area. Mine still works great after all these years.
Carter S.
Model Year 2003
-L2 Lt Taupe/Taupe
AJBP Security Group
APAS Monotone Paint
AWL Off Road Group
CKDP Floor Carpet
EKG 3.7L V6 Engine
GWA Power Sunroof
LBBP Courtesy Lamps
LNJS Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MVCS Jeep Badge
MVDS 4X4 Badge
MZLP 3.7L Badge
MZ3S Liberty Badge
NHMS Speed Control
XEAP Tow Hooks
Thanks for reading!
How do you go about getting one?
