Broken OME 927
Discussion in 'Lift Kit Discussion' started by LetFreedomRing, Mar 28, 2017.
  1. LetFreedomRing
    LetFreedomRing Full Access Member
    292
    Jul 1, 2010
    Pennsylvania
    Got in the Jeep yesterday morning and heard a snap. Has this happened to anyone or did my "luck" strike again? :happy175:
    Needless to say I am quite thrilled at the moment.... :emotions34:
    Lift kit is only 5 years old. Less than 40,000 miles on it. And yes, I wash the salt off of them. These springs rusted within the first year of owning them.
    [​IMG]
  2. tommudd
    tommudd Moderator Staff Member Moderator
    17,578
    332
    Never seen any OMEs look like that after 100,000 miles
    But like anything else things do wear out and things break.
    Just like the new 2018 JK that they were testing and broke down along the road .
    Will need to replace both of course to maintain height, so while bad another 170 bucks and back on the road again
  3. tjkj2002
    tjkj2002 Full Access Member
    10,614
    Dec 17, 2006
    Holy corrosion batman!!!!!!!!!!!!!!!!!!!!
    My rotors had next to no corrosion on them when my KJ sat for a entire year.In your pic that is like you never washed it and submerged it in salt water for a couple of years.
  4. LetFreedomRing
    292
    Jul 1, 2010
    Pennsylvania
    That's what is sad. I take care of my vehicles and the rotors I have on it currently are spotless after 2+ years. This vehicle sits outside and I was appalled with how fast these springs rusted. My oem springs had no rust on them when I removed them!
  5. LetFreedomRing
    292
    Jul 1, 2010
    Pennsylvania
    Already got a pair ordered. Supposed to come tomorrow. I sure hope the black coating holds up better on the new pair.
  6. JasonJ
    JasonJ Full Access Member
    1,521
    43
    Jul 8, 2013
    Michigan
    Maybe spray them with some epoxy clear coat or epoxy black... just in case.
    Looking at the rust on your knuckle, clevis, cv joint housings.... that's odd. It's almost like the environment where you park or drive is attacking your Jeep.
  7. LetFreedomRing
    292
    Jul 1, 2010
    Pennsylvania
    Everything has been like that since I got the jeep back in 2010 with 50,000 miles. The factory springs were rust free and are still sitting in my garage. The knuckle, cv housing, etc. haven't changed in the last 7 years.
  8. tommudd
    17,578
    332
    There has been a couple of Northeast Ohio KJs that were that bad that we've lifted at my place. But maybe I'm crazy but I wash good, wax the UCAs , spray the coilovers with a rust preventative spray, everything else gets painted 2-3 times a years
    But thats looks bad for sure:gr_grin:
  9. sparky123321
    sparky123321 Full Access Member
    228
    Oct 22, 2016
    New Hampshire
    That's surface rust. Looks like a normal older New England Jeep. My 02 from NY looked even worse with only 11,700 miles on it.
    Not trying to start anything, but I didn't think OME ever broke from what I read on this forum.
  10. tommudd
    17,578
    332
    Anything that is mass produced by man or machine can and will break.
  11. LetFreedomRing
    292
    Jul 1, 2010
    Pennsylvania
    And now that I think of it, one of my springs had a slight bubble under the coating when I first installed the lift. It later broke the coating and started rusting there. I wonder if it was a defect in the metal? I'll have to check it out to see if it was the same spring.
  12. krisP
    krisP Full Access Member
    483
    Nov 8, 2015
    NY/PA
    wax the uca's ?
  13. tommudd
    17,578
    332
    Yes sure do plus some other parts underneath couple of times a year, protects them, plus looks good If I don't wax it, coat it it gets painted .
  14. LetFreedomRing
    292
    Jul 1, 2010
    Pennsylvania
    Well, got everything swapped over. Both springs were broken. The driver's side was broke in 2 places, the passenger side in 1. I'm just hoping my rear coils hold up now...... :happy175:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  15. Dave
    Dave Administrator Administrator Moderator
    15,590
    WOW..........first I've seen of those braking like that.....
  16. LetFreedomRing
    292
    Jul 1, 2010
    Pennsylvania
    Thing I was surprised about is that the coil wasn't rusted all the way through and it still broke. I was also intrigued about the 2 pieces that came off the 1 coil are almost identical in size and where they broke.
  17. JasonJ
    1,521
    43
    Jul 8, 2013
    Michigan
    Almost makes you think something went wrong with the manufacture of those specific springs...
  18. LetFreedomRing
    292
    Jul 1, 2010
    Pennsylvania
    Yeah, just wanted to point out that those 2 identical coils came off the same spring. There are 3 total pieces which are pictured with the coil they came off of.
  19. sota
    sota Full Access Member
    1,507
    128
    I'd send 'em a note with the pictures.
    That don't look right.
  20. tommudd
    17,578
    332
    Too bad Seth is no longer with ARB-USA he would of had an answer for you.
    I'll check see if his buddy is still there
