StockBlack
Hi, I recently changed from a 98 Cherokee to a 2005 Liberty and had a question about the brakes. Both the Cherokee and Liberty do not have antilock brakes. With the Cherokee, I was able to lock up the wheels fairly easily under hard braking and the pedal would firm up before the bottom of the stroke. The braking on the Liberty isn't horrible but I can barely get the tires to squeal under hard braking and the pedal makes it to the floor without completely firming up. Pads and rotors are in good condition and I've bled the brakes. I've tried the test of pumping up the brakes with the engine off to look for the pedal sinking to the floor to check the MC and the pedal seems to stay steady.
All that is left in the braking circuit is the MC and booster and I wanted to see if this was just the way the Liberty's brakes are before I spent any more time and money trying to fix a problem that doesn't exist.
Thanks
Thanks
