One of the projects I have been digging thru. Not as easy as the "roof light" indication.
Being as since #19 is grounded thru the lightbar switch normally to turn the indicator on. The fog lamp indicator is controlled thru the multi function switch. The "sense" wire is pin 7 on the C2 connector of the Module-Body Control. Or it is pin 2 in the 10 pin multi function connector C1
I have not tried the following YET. One could pull the ten pin connector from the Multi-function switch. Put a meter on pin 2(front fog sense wire) and check for a voltage. If none is present, ground it and see if the light comes on.
My sense on the "sense" wires is that they are nothing more than a LOGIC ground telling the computer to activate said indication light.
