Ball joint question
first&lastKJ
Indiana
What brand lower ball joints do you use? Moog seems to be the most common.
I checked mine and there is no play but the boots are torn so I will be replacing them this spring.
Moog greaseables
K3199
first&lastKJ
Indiana
Thanks Tom, what about the uppers? I will replace them at the same time.
first&lastKJ
Indiana
I was just looking at the Moog lower ball joints. The grease zerk is on the side. The Auto Zone lowers I put on the 02 had the zerk on the top. When I installed them the zerk hit on the cv axle. I had come up with another solution to get them installed.
Aceofspades
Buffalo
I have a pair of lowers without grease fittings I can let go $40 pls shipping They are local store brand
Wrong ball joints, you installed the ones for a 2 wheel drive
4 wheel has the grease fitting at an angle on the side
Of course from Autozone.......
first&lastKJ
Indiana
So for the upper control arms what is the go to brand. Other than the JBA's which are obviously the best.
Someone hopefully will jump in and help you out.
I only use the JBAs since he has them for lifted and unlifted ,
Leeann
Maryland
I bought JBAs for unlifted Libbys. They actually were the same price (or just a couple $ more) as the cheap ones from the LAPS, but have replaceable, greasable ball joints.
