Any back window adjustment???
leerdmn
Central Florida
So I'm installing my new taillight guards(chrome steel), and I notice my rear hatch window is crooked. On the driver's side, it all seems good, with about 1/8" all the way around. On the passenger's side, the top is almost 3/4" gap at the top, and touching the paint at the bottom. I have tried to look for an adjustment, to the point of breaking the hinge cover. I can't see anything. Any ideas???
bigfella
San Diego, CA
I'm wondering the same thing. My rear hatch tailgate window is pushed over about 1/8 of an inch and hitting on the bottom of the pillar. It's starting to prevent it from closing correctly. Anyone have thoughts on adjusting it? The last thing I need is that window to pop when one of my kids try to close it.
Aceofspades
Buffalo
The bolts on the hinges let’s you move it around to line up the gaps. I’ve removed the whole rear glass and had to use wedges (and someone else tightening the bolts) to get it aligned perfectly again. If that’s what you’re talking about.
duderz7
Weiser, ID
You can shift or slightly if you loosen the hinge mounts, but sounds like you guys may have bigger issues.
