Hey guys, last night the lights on my girlfriends 2003 KJ Limited didn't come on when she turned the switch on. I've done a search and it seems to be a problem with these. Mine is just like everyone else's, everything works but the low beam. Highs are fine along with the driving lights. I've done some testing and hope that you guys can help me. So far I've switched the high and low relays, still didn't work. I tested both relays in the high relay switch and they both are fine. Or at least it was clicking and the high beams came on. In the relay socket I tested #30 terminal (top one) that the manual says should be hot with a test light. The high beam had power, the low beam did not. I also checked the fuses (#4 & 5) with the test light, light switch off they had no power. Light switch on and they both have power. It seems like my problem is at the socket. Would this be a result of the multi-function switch or the body control module? Or could it be a fusible link or something else simple? What do you think? If I get time tonight I may pull the steering column apart and have a look.
Thanks,
Thanks,
