I Would find a good reputable transmission shop and forget about it. Don't u need a new flywheel too? I hope you find a good shop if not just a dealer.
p:
I can't afford to pay for it! I replaced the flywheel the second time!
Here's the story.
I got a new clutch because the old clutch was stiff and slipping a little up steap grades. When they replaced the clutch the first time, the tech machined my flywheel. After the clutch was installed, it would chatter.
I showed them a copy of the FSM(factory service manual) where it said not to machine the flywheel that I got from TJKJ.
They said they would do the work for free if I bought the new flywheel, so I did. After the second job, a few weeks down the road it was chattering again, and making grinding noises(worse when running the A/C). They didn't warranty the work because I supplied my own clutch.
Now, Im stuck with a chattering, noisy, sloppy clutch until I do the job myself. And just recently, it makes a crazy "belt slipping" type sound when cold starting in the morning only. Im figuring the machined flywheel warped the new clutch, now I have a good flywheel, I hope, and a bad clutch...once again.
p:
