Alignment for 2.5 lift
05KJBaj
Hi everyone, I am getting a 2.5 lift on my kj (ome 927/947) and have 265/70r16 mt wheels. I have quite a lot of negative camber in the front because of my oversied tires and no lift, I guess it'll get better with the lift and alignment.
My question is do i get an alignment at factory specs ? If not what numbers
This thread has great information for Lifted alignment specs. https://www.jeepkj.com/threads/alignment-specifications-for-a-lifted-kj.58723/
Might want to print it out to help alignment shop.
Keep in mind that new OME springs will settle down a bit.
Another alignment may be needed after driving a few weeks to a month afterwards.
Are you using the OEM upper control arms or the JBA 4.5 upper arms?
05KJBaj
Keep in mind that new OME springs will settle down a bit and another alignment may be needed after a few weeks to a month afterwards.
Are you using the OEM upper control arm or the JBA 4.5 upper arms?
Thanks a lot, I bought used springs from the junkyard, and stock uca
05KJBaj
I already read this thread before, I was unsure of the end result. So if I got it right it is stock specs but 2.5 to 3 for the caster with the right .5 higher than left
