Had to get one from NAPA. Oh well. Wasn't cheap IMO. But anyone wanting to do this with the fog light switch and lights from a parts jeep, this is what I did.
Went to junk yard and pulled the fog lights with the brackets (that's important you'll need the brackets) and as much wiring as possible.
Also got the fog light switch too
First thing I did was mount the lights into the bumper then took both ground wires to an eyelet and bolted to the frame. Then , ran both blue wires from fog lights to driver side.
Remove grill and driver side headlight. Underneath the driver side headlight you'll see a connector hiding that has a blue wire. (Those one is hard to get to)
In order to get to that wire and splice in you can do one of two things
remove the entire headlight and grill support
Or go the route I did and unclip the connector from the passenger headlight, ambient temp sensor (if you have an EVIC/OTIS) and driver headlight. Once these are disconnected, pull the harness trough so you can get to it.
Should look something like this
Splice in the blue wire to that harness. Once done, all wiring is done if done correctly. Next, get inside the jeep and remove the kick panel under the driver side of the dash and add a relay to the fog light relay spot shown here
Now install the fog light switch and turn them on!
I'm posting this only because of the diagrams I've looked over and over did not make sense to me (granted some may be better than I) but I figured I'd post what I can to help those who will need it.
