ABS, ESB Handbrake lights on
a_ibrahem
UAE
Hello Guys,
I have 2007 liberty sport with 220K on clock
recently i got ABS, ESB, Handbrake and slide marks lights on in the dashboard
i have read a lot and found a common issue about rear sensors wires,
i did ohm test straight from ABS module connector after disconnecting the senors and wires are ok, the i connected the sensors and measured again and all sensors giving a reading around 380K Ohm, except for rear right is giving 5.5M ohm
have anyone found such symptoms before ?
or know how to test sensors or what value it should be in ohm test ?
Thanks lot guys,
Ahmed
Hello Guys,
Thanks lot guys,
Ahmed
Not knowing the exact ohm spec but 380k ohm is is way over any spec I've ever ran into for a ABS sensor.Heck 5.5m ohm is way to much.
Most that I test and are known good have 50 ohm's or less.
a_ibrahem
UAE
a_ibrahem
UAE
I have new one for the front ,and it measures around the same 380k ,just wanted to see if u guys tried this before,
Am getting rear sensor Saturday hopefully this solve the problem
Sent from my ONEPLUS A5000 using Tapatalk
a_ibrahem
UAE
After removing old rear right sensor found lot of metal dirt stuck on it, cleaned it and and measured it and it shows around 380k again :)
Connected it back and no alarms since then
Thought I update u guys
Thanks,
Ahmed
