A bit of a growl...
Geof3
Colorado
Be awhile since I've posted, but this one has me stumped. 2004 3.7. I've got a bit of a low speed "growl" around 10-20mph. Seems to be from the rear end. I've got Wrangler Dura-trac tires, about 9 months old. OME 1.5 lift. I've had the thing off the ground, no unusual play front or rear, all corners rotate easily and smoothly, CV's seem good, diff has been checked recently, both drive shafts rebuilt about 12-15k ago. New-ish transfer case. The manual mentions a low speed growl that goes away (mine does) could be rear axle bearings, worn etc. However, when spinning the system they rotate with no noise and feel very smooth. I'm stumped. Could this just be tires, or is there some other way to go about solving this thing. If it's tires, no worries. However, if I've got bearings going bad I'd like to address them and move on down the road, but I would rather not replace things that don't need it yet. Mileage is about 135k. Thanks for any help!
kejobe
NE Ohio
Could possibly be the tires. As far as the bearings, when mine went bad in the rear, it didn't growl. It was more of a howl at about 35-40 mph. Same with the '95 Chevy 1500 I had. Front hub bearings will usually growl though.
Have you tried rotating the tires?
Geof3
Colorado
I haven't yet. I should have done that when it was up in the air doing other things a couple of weeks ago. Didn't even think about it. I'll give that a shot and see what happens. Seems a little too deep though for tires... Interesting you mention a howl, I do get a bit of that around 45 MPH as well... Hmm??
