Sirthor1881
So what does everyone think about this lift kit?
FROM EBAY PAGE:
Masterkit1 now offers the best suspension lift on the market for the Jeep Liberty 2002-2007. Give your Liberty the look and the clearance it needs to go offroad with our new Suspension lift 3". Masterkit1 uses a unique way to lift the vehicle with external front strut extensions as well as longer rear coil springs ans shocks.
Our kit is offering by far the quality price ration on the market while allowing you to complete your own installation pain free and without hassles. It is easy to install with regular maintenance tools as it comes with detailed instructions. All that is left to do once the job is done is to go to the shop for a wheel alignment.
The kit does not go over 3" in order to avoid the front axle CV joints from binding. he external front strut extensions are made of laser cut solid 3/8" steel plate. They are also double welded (inside and outside) for better quality, resistance, durability and precision. Longer shocks and coil springs are used at the rear to retain impeccable ride quality. Compressor tools are not needed for the job.
The installation of our 3" suspension kit allows the use of larger tires increasing clearance and improving the look of your vehicle. It is always recommended to install the kit first before buying the tires. You can then make the tires fit on your truck, and not the other way around. Bigger threads and different companies account for slight differences in the tire real size.
The Kit contains:
(2) Rear coil springs.
(2) Rear shocks.
(2) Front strut extensions.
Detailed instructions with pictures.
http://cgi.ebay.com/ebaymotors/Jeep-Liberty-2002-2007-3-Steel-Suspension-Lift-Kit-_W0QQcmdZViewItemQQhashZitem35ad953bb9QQitemZ230545505209QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
FROM EBAY PAGE:
The Kit contains:
(2) Rear shocks.
As an eBay Associate we earn from qualifying purchases.
