245/75R16 with no lift
bfaas
Pittsfield, MA
first of all i'm dying to get rid of these crapyears and get new tires. right now i'm thinking about going with General Grabber AT2s but i know someone else on here put 245/75s on with no lift. how would this work with the profile of the grabbers, rubbing, etc? or should i just go with the 245/70s? i want to go with the biggest tire possible with no lift. thanks.
If you have a pre-lowered KJ 245/75's will fit,but since you have a '06 stick with the 245/70's unless you don't mind major rubbing or major trimming.I ran 245/75 MT/R's on my '02(pre-lowered) KJ for the first 3000 miles,it only rubbed on the fog lamp door's at full turn,no pinch weld contact.Then switch to 225/75 MT/R's till I lifted it(then went to 265/75 MT/R's).
KJ2005
Las Vegas
how would you know if your liberty was pre lowered? mine is a 2005 4x4 that had a trail rated decal (funny because it looks like it doesn't even have a single skidplate below)
If your KJ was built before April 12th 2002 then it is pre-lowered,anything after is lowered 3/4".You have a lowered KJ being it's a '05.
