What are my locker options currently for an 03 with SelecTrac?
Begle1
I have an '03 Liberty with the 3.7, SelecTrac and automatic trans, and I just installed the ol' OME lift kit from Rocky Road.
I'd like to get some lockers next. What are the good locker options currently?
The rear differential is open currently. I have stock tires now but figure I'll end up with 245/75R16's when these wear out. (I gather those are the biggest that'd fit.) I plan to never go bigger than that. This is a daily driver that needs to go up and down muddy, rutted-up trails and occasionally also drives on wet/ muddy pavement where I very much do like to use the "Full Time" mode. I'm not rock crawling or trying to go fast off-road.
Would it be wise to use a selectable locker on the front to avoid any possible on-road handling problems, and then use an automatic locker on the rear to get three-wheel drive? If I ever get stuck on three wheels then I can activate the front locker and hope for the best?
Or is there an automatic setup that works good in the front with SelecTrac, even on-road? Am I best off just going selectable on both ends?
Thank you, I know nothing.
Begle1
Doing a lot of reading, it seems like I can find any opinion I want in terms of how badly an autolocking differential in the front affects road manners, or even in the rear.
This is my loaner car too, so I'd like to make sure road manners are as friendly as possible. I've always felt like "Full Time" mode on the transfer case has been as useful and forgiving on slick pavement as one can ask for on a vehicle without any electronic aids.
I'm trying to wrap my head around what kind of funny things an autolocker could do while cornering on slick pavement.
I'm currently leaning towards a clutch-based LSD in the rear and a selectable locker in front, or selectables front and rear, to try and make road manners as forgiving as possible... But if I would be happy with lunchboxes in the front and rear, I could certainly be sold on that due to how much easier and cheaper it would be.
Don't lunchbox the front it will blow it to bits! The alloy housing isn't very strong.
DefCon2
Your idea of having a selectable in the front is good, but not entirely necessary. I've had Dana Truetracs in the front of most every Jeep I've had. It will only engage when a wheel spins, so you will always anticipate when it will engage. It does not negatively effect road manners or drivability. Some people are afraid that the front diff could grenade, but there would only be a risk of it if you were hammering the throttle and creating massive wheelspin. Moderate throttle would have the locker engaging before the tire could get up enough revs to create any real stress.
DefCon2
A lunchbox locker is a generic term for a locker that engages by itself by use of an internal planetary gear (or similar) when one wheel on the axle begins to spin. Selectable lockers engage when the push of a switch locks the gears either by an electronic servo or pneumatically.
They aren't very nice for on road use, if you search on here you can find lots of posts about them, they are the cheapest option but far from the best for a road car. The front end is a well known weak point on the KJ, unlike other Jeeps it's an aluminium casting with modified Dana 30 internals, probably one of the weakest ever made, on the other hand the rear is a later 8.25 which is very strong & will even handle the full torque of the CRD in 2wd mode.
As I said, it's been well discussed over the years, there's a recent thread on here about fitting Spartan helical lockers that are a bit kinder to the driveline, have a search
u2slow
BC
I ran a powertrax no-slip in the front for some time. In 2wd it's like it's not there. When in 4wd, your throttle is the locker's 'on' switch. Every gear shift, (manual trans) unlocks and re-locks the locker, with a splash of torque-steer. This can be unnerving at first, but you do get used it.
Then I swapped from the 241 tcase to the 242. Full-time was not so cool with the locker. There ends up being a pronounced backlash in the entire drivetrain as the tcase differential tries to 'eat' the backlash before the locker engages. Part-time mode alleviates that again.
Anyway, the front locker came out, and I have a Torsen (aka True-trac) to go in on the next bearing overhaul.
Rear has had the factory trac-lok since the beginning. My dodge trucks have rear Lockrights that I put in. I think a rear auto-locker would have the same quirks with the np242's full-time mode.
mercdudecbr600
I have front tt and rear ox locker. TBH i wish i had just put a tt in the rear. But I find that having an open rear in the winter with ft 4wd keeps things real predictable with good traction. So IF you get a locker, put it in the rear. The c8.25 also happens to be a very strong unit and the d30a is not particularly beefy.
An e locker is the only way to go if you do it but it is spendy and relatively involved.
FormerXJGuy
This is unrelated to front diff (looking at maybe Spartan Helical for that myself), I'm more interested in your 242 transfer case. Is that the classic NP242 from the Jeep XJ era or a different model for the KJ? I haven't found much on the subject other than one or one like the NP242 was put in the KJs.
u2slow
BC
They are the same 242 in function, but the KJ one has a bigger rear output shaft than the early 90's XJ version. And it's sealed; pulling the slip yoke off doesn't leak any fluid.
