235-85
WarVet
Texas
Have any of you guys run 235-85-r16's without backspaced rims and no rubbing? I only have a 3 inch suspension lift...
Cardhu
Great White North
they may rub being so tall with 3 inches of lift. Rear will need bump stops to keep fenders, stock gearing will be your biggest issue and it driving like a dog. your going to want 4.10s.
see all previous posts about 265 75 16's as they are similar in diameter.
WarVet
Texas
Yeah....Ive researched the 265 75 16's....was going to go with them but I was concerned with the width...gonna regear to 4.10 this summer sometime but I am needing tires first....I have shot measurements on my wheel wells and it seems like they should fit....Just being xtra careful
They'll rub on the sway bar when turned full right or left some
what do you measure from middle of wheel to bottom of flare, everyones 3 inches is different it seems anymore
PLUS if you're going to install them get and not regear till later you'll hate driving it, or at least I did
WarVet
Texas
I am disabled, so I might drive 5 miles a week, so I sould be ok....I went from the center of the wheel and spun a circle like a compass holding at 16 inches for 32 inch(31.8) tires and it seemed to have plenty of room...either way the guy at the tire shop said hed put them on for free no obligation so I could check em out...
JLRockies
Draper, UT
I had them on mine for 3 years with a 2.5" lift and I actually go off road. I re-geared after the first year but the extra awesomeness of the CRD was able to compensate.
