235/75/15 on an 08” Liberty
Clifford Brown
Hope everyone’s doing well I wanted to ask currently I’m running 31/10.5/15 on a stock height 2008 Liberty they just happen to rub a little much for my liking. I wanted to ask for opinions on 235/75/15’s knowing the suspension has sagged now will these tires fill the wheel wells or just look to small? If not could anyone recommend tire sizes?
Thanks so much!!
How are you running 15 inch rims and clearing the brake calipers?
Clifford Brown
The rears cleared the calipers and in the fronts I shaved the slightest bit off the bolt running through the lower control arm and I’m running a 5/16” spacer works perfectly haven’t had a single problem
Not yet, bad idea running thin spacers, less lug for the lug nut to grab onto
and yes 31s need 2.5 inches of lift to run and preferably 4.10 gearing
cburkhart
arkansas
You Can run 15in Steel wheels I know on a 02 liberty I run 31x10.50r15 with 8in steel wheels
LOTS of difference in steel
then you add 8 inch which some think looks cool with 3-4 inches of backspacing and of course won't hit suspension parts, just body parts
cburkhart
arkansas
but 5x 4.5 bolt pattern
cburkhart
arkansas
I Have a 3in Rough Country lift on mine with 31x10.50 15 rub a little if you are in rough Terran
