2012 Radio works intermittently
Freedomchief
OEM Media Center 130 with satellite works for about 3 seconds and then cuts out for three seconds continuously. This affects everything on the radio (Paired phone, AM, FM, SAT, volume). 2 fuses ( 15 amp and 30 amp) are associated with this system and both are good. I can hear a click in the speakers as they kick in and out. I replaced the radio with 4 previously used radios yesterday. All of the previously used radios have the same problem. Is there an amplifier associated with the radio? If so where is it located.
nikiforo
Ho lo stesso problema,tolto la radio perché si era incastrato il CD,rimontato,non c'è più audio,mi hanno detto che dipende dalla centralina,quindi devo portarla dal elettrauto,a meno che,qualcuno abbia la soluzione e la pubblica:jeep cherokee kj liberty del 2006.
MsRandiCook
Cookie
Factory radios were pretty hardy. But not worth fixing or direct replacement. My Bluetooth receiver just went out. So it's time for an aftermarket head unit.
