2007 Jeep Liberty Bilstein 5100s and lift springs
WheelNut
Vancouver, BC
It looks really good! I’m looking to do the same suspension lift this winter or spring. Hoping to paint the fenders black like you have done too.
JP85
I used car guys plastic restorer on the fenders. It last about 3-6 months between applications.
JP85
I went ahead and put Hankook Dynapro AT2 245/75R16 tires on the Jeep. At full turn I get a small amount of rub on the fender well. Would wheel spacers fix this?
Make it worse
where is it hitting/ rubbing at ?
Some areas you can heat and push back, if on the pinch weld , then there is a way to bend them over
JP85
Runs on front fender well I’ll try the heat method
