Natecroix
Hi all, I just replaced the engine with a reman longblock in my 2006 Liberty.
Currently experiencing a no crank/no-start condition & my snap-on scan tool cannot communicate with the engine module.
No Fuel Pump Prime on Key-On
ASD relay is tested good
Starter relay is tested good
ASD relay does not click with Key-On or start
BCM codes: PCM Messages Not Received, VIN Message Not Received
SKREEM codes: PCM Status Failure
ABS codes: Lost communication with ECM/PCM; Lost Communication with TCM; Implausible data; Implausible vehicle configuration; Original VIN mismatch / Missing
I have pinned out the OBD Pin 2 to the engine harness and there is continuity.
All grounds on PCM harness are good.
PCM is receiving 12v in start/run
The starter turns when starter relay is jumped with wire
The PCM worked great before swapping the motor; it is the original PCM.
Only thing I can think of that could have caused a pcm failure is re-connecting the battery when the engine was out in order to roll up the drivers window.
Has anyone had experience with this issue and found a common problem (and hopefully solution!)
Thanks!
Thanks!
