Well let me start of with about a week ago i replaced my water pump, it was leaking antifreeze, easy fix, did it with my buddy in his dads shop. It ran fine back to my place, but then i let it idle while i ran inside ended up letting it idle longer than i thought and when i got back out side i saw what no car owner wants to see. I was way over heated and the antifreeze was boiling so of course i turned the car off and let it cool while i called my buddy and ran through everything we did. Then we finally realized we forgot to plug the fan back in. So we of course plugged it back in and filled it back up with antifreeze, ended up using another full can of 50/50. We then turned the car back on and it started fine. We let it idle a while and everything seemed fine. Fast forward to a couple days ago. Mean while i drove it about 300 miles back to college. I should let you know that before this my engine light has been on due to a O2 leak or bad sensor code P0137. But 2 days ago i started to feel a jerk or hiccup around 60-70 mph. At first thought it was just the wind, my college is in erie and its been windy, but it was too consistent. So i ended up going to advanced auto and getting it checked and they came up with the new codes P0306 and P2317. Now i know the one is cylinder 6 misfiring and the other one is an ignition coil, coil "F". Now with me being in college i dont really have the money to blow so i was first going to check the spark plug. but dont know if ill really be able to get to it till i go back home. So what im asking is how bad is this and do you think a simple tune up would fix it, it does need one. thank you for your time.
