2004 Fog Bulb # - Reading Dim and Yellow!
Screw Singular
Ok finally had a chance to get the flashlight and discovered one adjusting screw. It is on the top slightly of to one side on each fog up front. Will play with them and see which way it moves. On thing is for sure these new 9005 bulbs match colour of the Piaa headlight bulbs, and are quite bright on illuminating the sides out in front of the kj.
How come when the headlights are on low beam and fogs turned on, when you go to high beam the fogs turn off? I guess they want to minimalize power drain and have you focus on the distance only.:confused:kopkrab.gif
There is only one adjusting screw per foglamp and it only moves it up or down.As far as the fogs turning off when you turn the brights on it's to be legal in all 50 states.
Mod?
I guess that applies to Canadian vehicles too. (came with block heater but no floor lamps LOL )
Is there a way to make a mod so that the fogs will stay on with high beams?
2nd link not working
Thanks Luke ...
2nd link does come up with error code.
