Hello all,
I have an '03 Limited with no working low beams or tail lights, high beams work. Went out all at once. Bulbs are good. I can not hear a relay clicking when turning on lights. Where is the low beam relay located? I have switched out all relays I can get to under the steering column on the back of fuse panel with no luck.
I did see a post listing it directly to the left of the high beam relay in fuse panel, but I do not believe this is correct. There is only a module there. Any help would be great, thanks.
Lou
Lou
