Gwraalstad
- Joined
- Aug 4, 2021
- Messages
- 8
- Reaction score
- 0
OK Guys/Gals. I have read all the threads on how to fix this problem but to no avail. I've tested all the relays and they all work. I have power through the fuses for the high beams but no power through the fuses for the low beams. Attached is a pic of the back side of the Junction Box. Had one heck of a time getting it. Correct me if I'm wrong but the relay in the upper right corner is the low beam relay. It works. All of the relays in that junction box work. So I'm getting power to the relay's and they are functioning correctly. Closing and opening as power is applied. Is there another relay/fuse between the low beam relay to the fuses? The schematic on page 8W-50-3 does not indicate any other relay or fuse. All wiring looks good. Help!
