Thanks for your support and advices guys
here an update of what I did with my jeep.
- I have change the cam shaft sensor, crank shaft sensor, checked the TPS and it's completely in good condition checked the coils and they are in good condition as well, cleaned the spark plug as I had a feeling they will flooded again and "yes they did."
-I did start the car today and it run from first try but the engine was shaking a bit and it did increase when it get warm I record the live data as @J33Pfan required and here the beginning, middle and end of the record data using Autel maxiscan Ms509 This is the best scan I have don't ask for more
PLAY BACK 0/60
DTC-CNT 1
FUELSYS1 CL
FUELSYS2 CL
LOAD_PCT(%) 12.2
ETC (℃) 58
SHRTFT1(%) -33.6
LONGFT1(%) 0.0
SHRTFT2(%) -33.6
LONGFT2(%) 0.0
MAP(kpa) 91
RPM(/min) 799
VSS(km/h) 0
SPARKADV(º ) 5
IAT (℃) 55
TP(%) 13.7
O2S B1S12--B2S12--
O2B1S1(V) 0.880
SHRTFTB1S1(%) -33.0
O2B1S2(V) 0.880
O2B2S1(V) 0.960
SHRTFTB2S1(%) -33.0
O2B2S2(V) 0.940
OBD OBD2
BLAY BACK 31/60
DTC-CNT 1
FUELSYS1 CL
FUELSYS2 CL
LOAD_PCT(%) 8.6
ETC (℃) 74
SHRTFT1(%) -33.6
LONGFT1(%) 0.0
SHRTFT2(%) -33.6
LONGFT2(%) 0.0
MAP(kpa) 92
RPM(/min) 716
VSS(km/h) 0
SPARKADV(º ) 8
IAT (℃) 67
TP(%) 13.7
O2S B1S12--B2S12--
O2B1S1(V) 0.820
SHRTFTB1S1(%) -33.0
O2B1S2(V) 0.800
O2B2S1(V) 0.900
SHRTFTB2S1(%) -33.0
O2B2S2(V) 0.900
OBD OBD2
BLAY BACK 59/60
DTC-CNT 1
FUELSYS1 CL
FUELSYS2 CL
LOAD_PCT(%) 9.4
ETC (℃) 84
SHRTFT1(%) -33.6
LONGFT1(%) -33.6
SHRTFT2(%) -33.6
LONGFT2(%) -33.6
MAP(kpa) 98
RPM(/min) 538
VSS(km/h) 0
SPARKADV(º ) 10
IAT (℃) 72
TP(%) 13.3
O2S B1S12--B2S12--
O2B1S1(V) 0.800
SHRTFTB1S1(%) -33.0
O2B1S2(V) 0.740
O2B2S1(V) 0.900
SHRTFTB2S1(%) -33.0
O2B2S2(V) 0.840
OBD OBD2
I keep it running until it's warm up to the normal running temp and finishing the records "around 15 min" than I switch it off it didn't stall which is good, even I move it from it's place and every thing was fine except the shaking, I try to switch it on again after 1 hour It just start for few second and stall again. fuel smell from exhaust, I open spark plug in cylinder 1 it's flooded again.
Open to your comments guys what do you think? what is next step?
