2002/2003 Hypertech tuner support
LetFreedomRing
Pennsylvania
The cage and lack of stock washer bottle actually brings alot of cooler air into that system then you think.That hole left by removing the stock washer bottle and no front wheel well liners shoots cold air from the rotating tires.I also heat wrapped the plastic tube,that helps greatly.
Unfortunately I still have the wheel liners and washer bottle. Although I was impressed that I could look straight down inside the box and see the ground. It almost seems less restrictive than the stock setup, at least for fresh air IMO.
