2" Lift recommendations
JeepLegend
Kj Legend
Hey guys was thinking about lifting my jeep with a BDS Suspension 2" Lift Kit nothing to crazy lol.
Has anyone lifted there jeep with this kit ?
If so, would you recommend it?
Or are there any other lift kit you guys like, that you would recommend?
Thanks
JeepLegend
Kj Legend
Thanks
Dang looks like I posted in the wrong section sorry guys still new at this
BDS is ok but expensive
By the time you buy the kit, you also have to buy front shocks, then rear shocks that come with the kit are junk so you end up paying more than you would for a OME lift with either bilstein or OME shocks
If only a small lift I can give you the parts number for springs and shocks
JeepLegend
Kj Legend
Appreciate the info. Perfect I'd like that. Thanks !!
small lift
OME 926 fronts, rear 947s this will give you about 1.5-1.75 over new stock height
You can use either OME or Bilstein front shocks , just the same number as stock height
rear the same thing
OR
if you want 2.5 inches over new stock height go OME 927s front and 948 rear , front shocks the same as above, rears go with ones for a 99-04 Dakota Club Cab 4x4
front bumpstops teraflex, they replace your original ones
rears use two hockey pucks per side bolted down to the lower spring perch plus leave stock ones in place
This setup will work better since you have that bumper hanging off the front
Stock spring rate in front is 310 lb , 926s are 375, 927s are 400
