cl350rr
Hi, I have a 2005 Liberty, 2.4L/6sp, 2WD sport, 78,xxxmi. I have been chasing an engine hesitation problem and am hoping to find someone who has delt with it before.
It has not thrown any codes, I have been driving it for about 8,000 miles and it has done this since I got it
symptom, sitting at a stoplight idling fine, when I go to accellerate the engine stumbles until it is over 2000rpm. other than that the engine runs and idles smoothly. if I get below about 1500rpm while driving and try to accellerate, it will buck a few times then smooth out when it gets close to 2000.
I know a 4 cylinder does not like to be at low RPM but this is somewhat dangerous as It takes a second or two for the engine to rev up before I can leave a light. and if the ac is on, it makes the situation worse. if the engine is not above 2000 rpm when I engage the clutch it takes longer for it to smooth out and run correctly.
I have replaced the plugs (factory recommended), air filter, cleaned the map sensor and throttle body, and am about half way through a tank of gas with injector cleaner in it. no affect on the problem.
I would appreciate any advise
