port67
I know there are a lot of post regarding this but I have not found the answer I was looking for. My liberty's A/C was working fine blowing cold air and than cut to warm/hot air. Prior to this there was no symptoms of trouble. I had two separate mechanics hook up there gauges and they did not comment on pressure issues. The clutch is not engaging on the compressor. I am able to spin the clutch with no resistance (with engine off and with engine and A/C running), is that normal? There is 13.2+/_ volts going to the clutch so I know it is getting power. The belt does not smell and is running smoothly. I am 80% sure its a bad clutch but never worked on A/C systems so I need feed back.
(banghead)
(banghead)
