06 Liberty 42RLE Trans Flush
Canuck
Ontario Canada
The trans in my old Liberty didn’t seem to be shifting all that great, it has 139,000 km on it and had one previous filter change.
I dropped the pan and replaced the filter, the pan drop replaces about half the fluid, the dry fill capacity is listed as 8.8 quarts. So I decided to do a full flush, you have to remember not to start it and mix the old and new fluid prior to the flush. I removed the cooler line on outlet side of the cooler, driver side. There is a small clip on the cooler line and then it pulls out. I used a 2’ piece of 3/4” heater hose and slipped it over the fitting on the cooler. On the initial fill prior to start up I overfilled the transmission by about a quart. I put the heater hose into an empty 5 quart transmission fluid jug and started the Jeep. The fluid comes out relatively slow and I kept pouring in fresh fluid until the empty 5 quart jug was full of the old fluid and then I shut the Jeep off. When I shut it off the Jeep the fluid coming out was clean, bright red.
So far the results are noticeable, it shifts smoothly. The old fluid didn’t have a burnt odour but was very dark. I used two 5 quart jugs of Mobil ATF+4.
