Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Easiest is any Chrysler 3.7 from 2005 to 2012, treat it like a long block swap and move over all the existing sensors and hardware like intake and oil pan. I found only a couple of sensors were different 2006 to 2012.
I believe on the newer year blocks a hole must be tapped for your Power steering pump bracket. The hole is there but not used. Here is a list of available donors. But stay 05 and newer so you don't have to swap the reluctor rings. Which would require removal of the crank.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
