05 Engine Changes
loves_off_roading
York, PA
On the Allpar website I noticed that the 3.7L engine received a couple changes in 05. It got a new cam profile, lash adjusters, rings, and a 9.7:1 compression ratio.
Just wondering if you guys think that these changes affected the engines long term reliability?
AlexKJ
Earthquakeland
In 2005, the 3.7 engine was treated to numerous economy and idle-quality changes, with a new cam profile, lash adjusters, rings, and a 9.7:1 compression ratio. The cam profile change, IF that means timing change, would change the torque curve, that's all.
Compression ratio
- 9.1:1 to 9.6:1
- 210hp to 211hp
- 225 ft/lbs to 236 ft/lbs
- valve timing (only lists duration in degrees, no lift):
* intake - 236° to 245.7°
* exhaust - 250° to 261.6°
All above is another reason that newer 3.7's have more issues then the older 3.7's.Longer duration equals more stress on the valve train.
And a lot more discussion in http://www.jeepkj.com/forum/showthread.php?t=41083&page=2
Have fun :)
