03 kj lift advice
Discussion in 'Lift Kit Discussion' started by Btechvft70, Jan 16, 2020.
  1. Btechvft70
    Btechvft70 New Member
    Jan 16, 2020
    I am new to jeeps. I just acquired a 03 kj with low miles in very good condition. I'm wanting to turn it to turn it into a hunting rig. Looking to lift it 2 or 3 inches to run bigger tires. I am wondering if someone could point me in the right direction. It seems OME is the way to go. There seems to be alot of choices in springs shocks and all I'm just wondering what works the best. Also is the any company that sells a full ome strut assembly. Thanks in advance
    Gerald Thomas likes this.
  2. jeeptorino68
    jeeptorino68 Full Access Member
    811
    21
    Nov 28, 2011
    Oregon
    Gas or diesel engine?
  3. Btechvft70
    Jan 16, 2020
    3.7 gas
  4. duderz7
    duderz7 Full Access Member
    299
    49
    Jan 20, 2016
    Weiser, ID
    Running ome 927 and 948 with Bilstein on my 05 with 3.7 and I love the ride and capabilities. Someone (Tom) gas the parts list memorised. Hell post soon. Let us know if you find the list sooner with your search.
    Gerald Thomas and tommudd like this.
  5. kejobe
    kejobe Full Access Member
    352
    31
    Sep 5, 2016
    NE Ohio
    From just a few threads down:
    OME springs 927 front, 948 rear
    teraflex front bump stops
    rear 99-02 Dakota CLUBCAB 4x4 shocks
    use Bilstein shocks ( www.shockwarehouse )
    front shocks are stock bilstein
    also 2 hockey pucks per side bolted down to the lower spring perch, 3/8 inch bolt, 2.25 inches long with lock washer and nut of course to hold them in
  6. tommudd
    tommudd Moderator Staff Member Moderator
    17,469
    279
    ^^^^^ good job
    jeeptorino68 likes this.
  7. jeeptorino68
    811
    21
    Nov 28, 2011
    Oregon
    That should let you run 245 75 16 safely. A bit bigger depending on if you get wheels with more back spacing, want to trim, etc
  8. tommudd
    17,469
    279
    and then you would need to regear
  9. duderz7
    299
    49
    Jan 20, 2016
    Weiser, ID
    I don't think you "need" to reheat, but it would surely be beneficial. I'm running this size tire without a regear, but make sure to not hey a 10 ply tire to save some weight. I'm sure my mpg suffers well general peppyness, but it moves along fine.
  10. tommudd
    17,469
    279
    Well all depends on if you want it to run like it did from the factory OR be down on power, gas mileage, extra wear on the transmission etc
    Depends on how you look at it
