Have a new motor sitting on the stand atm. Am moving everything over valve covers, sensors, oil pan etc. The removal tool for the harmonic balancer worked to remove it from the old blown up motor. But the install tool you can rent from autozone isn't long enough.. like the piece that threades in to the crank and then to the through bolt on the tool will NOT thred into the crank because its not long enough too. Is there a trick to this or a tool that will actually work? If not im going to have to get a bolt that size, super long with some washers and a piece of pipe and nuts and turn the nuts? Really hoping there is just a tool that will work tho. Anyone have any help?
