245/75r16 Yokohamas with Cragar Soft 8 16x8 5" BS?
kayadog
245/70r16 Yokohamas with Cragar Soft 8 16x8 5" BS?
Hey-- I talked myself out of the 15" rims. I am mail ordering and need to be sure they will fit so I will stick with 16".
Does anyone run 245/70r16 Geolander A/T-s' on Cragar 16x8 soft 8's w/ 5" of backspacing?
My 05 Sport is stock.
kayadog
245/70r16
note: I meant 245/70r16. I made a mistake in the thread title and can't edit it.
K Dje Ryu
Casper, Wyoming
I'm not completely positive but, I think you'll be ok. Might require some minor trimming of some plastic but, nothing too bad.
kayadog
Am I better of with the 16x7" rims with 4.5" inches backspace?
K Dje Ryu
Casper, Wyoming
Not sure, I haven't really looked at wheel options much yet. Pretty sure I remember someone saying they run with those soft 8's though
jerbacher
Twinsburg, Ohio
jeepjeepster runs that setup, i think. He says he gets just a tiny bit of rubbing at full turn, but he's lifted. You might pm him to get some first hand experience with those wheels and tires.
Yes, I run that setup and love it. The rubbing is very minor like jerbacher said and no trimming is needed with my rustys lift. :)
kayadog
Does anyone have any experience with this set-up on a stock KJ? I don't plan on lifting mine.
They would most likely rub but it probably wouldnt be bad. The rear DOES rub at full flex. Its best to get some small extended bumpstops and mount them to the spring perch.
kayadog
Am I better of going with the 16x7 4.5" backspacing? These are mail order and not returnable so they have to fit.
