Cold Air/ Ram air intake using the stock air box
renegade 04
Albany New York
All it took to make this cold air intake was some duct tape, pipe insulation, file and hack saw. This has improved performance off the line and on the highway. Total project cost maybe 5 to 10 dollars at the most.
same here and that requires removing that radiator cross member.
With all that duct tape on it, it's going to be extra work, except if renegade04 doesn't have the giant shroud.
RenKJ
Canada
Won't the duct tape come off first time you get mud or water on it?
renegade 04
Albany New York
Yes I do have the large shroud on my libby. The duct tape also stays on well once you clean the surfaces it is adhering to well. Overall I think the duct tape is a start and I have plans when i have time to come up with a permanent solution.
I run a 3 inch tube from the grill straight into the box , works great has for several years now with no issues
I have the 2 fans and big shroud, I've never had to remove my fans/shroud to do an oil change. Really easy to get the filter from under, even back when the KJ was stock height.
can you post some pictures of this Tom?
Here ya go my good friend :icon_lol:
here you can see the tube going into the airbox right below the original scoop
little better picture of it
grill area, was always going to trim it off at an angle like I did the prototype ( and sold it LOL ) but its worked that way for 6-7 years at least now ( had a thinner hose there before that. As far as water getting in, never had an issue and when driving up creeks just stuffed a rag in
jeeptorino68
Oregon
thanks, for the pics Tom, that is what i was picturing, but i just wanted to confirm, i have been planning something like that too, i need to get to it before all the summer road trips.
Anyone remember the LTT intakes? Weren't those a similar design?
