surging/lean condition?
marky38
michigan
Hi there...2007 liberty...200k miles....Ive always had a slight surging occasionally since we bought it with 177k miles...Its always had a spark knock with the a/c on too....it seems the surge, or whatever is happening has been worse lately...its been hot and humid..i dont know if that has anything to do with it....im about 8k miles away from a 30k spark plug change...could that be a cause of the problem?..it idles good and runs well...no check engine lights.....could the fuel pump be on its way out?...any input welcome...Thanks
marky38
michigan
I do believe the 2007 have a throttle by wire and would have to replace the whole throttle body correct?
2007 was the cross over year, early models may not have it. Attach a pic of your throttle body.
marky38
michigan
Yeah it's a throttle by wire...could that throttle body cause a lean/surge?.can you clean those ?..thanks
All good questions, I do not own a throttle by wire set up.
It is probably two components. One is the gas pedal which actually is a sliding poteniometer.
The other is the drive by wire throttle body.
If there are issues a good shop scanner may find stored OBD2 codes.
Cleaning, I would refer you to a 2008 factory manual: Post 19 & 18 should work without ad blockers. https://www.jeepkj.com/threads/factory-service-manual-links-kk.74533/
There are other threads re the throttle bodies, just not sure where they are, have a look in the KK section.
